Greetings,
Ive narrowed down my choice of secure deletion program to the latest version of Eraser, CyberScrub Pro, or BCWipe. I thought it might be helpful for the Admin here, who I take it is also the Eraser programmer, to give us his thoughts, as objectively as possible, regarding the relative strengths and weaknesses of his product, vis-a-vis competing products. In my case, it is obviously the two mentioned above Im interested in hearing about, relative to Eraser.
Obviously, if users themselves with relevant and reliable experience or insight into these various products also want to contribute, that would make the thread all the more useful.
I like the fact that Eraser is free, and is part of the free software movement. And, having been around computers more than Id like, I highly value product stability, and excellent, comprehensive documentation, written by persons with a good command of English. The Admin certainly has that, as does the product description information at the Eraser website.
But, it seems that with Eraser, one has to perform two wipes: one from the hard drive, and then a separate floppy-based wipe for the swap files. It is stated that one can get around this by temporarily disabling the Windows swap file (ie virtual memory), but--is this disabling (and then re-enabling) process straightforward, or can it turn to disaster, as can so easily happen with computers?
Many people seem to use and like CyberScrub, and it seems very full-featured. I did find one, or two, people who mentioned glitches; one said the program mistakenly ate part of their OS, mistakenly deleting 13,000 files. The other said when selecting one file for wiping from the right-click menu, the program was poised to delete many more files than that, although its confirm/cancel command allowed the user to stop, and successfully re-select the single file to be wiped. Supposedly, if you go through this start-stop process the program then accepts the proper single file the second time you select it. I dont know if these two complaints were for the latest version; I dont think so.
BCWipe seems like a very well-programmed product. My complaint, though--the same one I had several years ago when I used their free (at that time) shareware version--is that the people writing the product info on their web pages and providing email support dont have a full, proper, and exacting command of English. Given the importance of a full, clear, and nuanced understanding, by the user, of how this kind of product works, Im still somewhat hesitant to commit to this product.
Last, I note that it appears that neither CyberScrub nor BCWipe require a separate, floppy-based wiped to take care of the swap files.
The other basic question I have, and maybe the Admin will be kind enough to educate me, and others, on this, also, is this: exactly when is it necessary to use a drive "scrubber" ala Cybercide, vs. a drive "cleaner" ala CyberScrub, Eraser, or BCWipe?
For example, I get the impression that if you just want to wipe your own:
- files/folders, or
- free-space (up to and including, say, an entire volume or drives worth, providing its just your data and not the OS, itself, you want to wipe)
...then a cleaner is fine. However, if you want to literally wipe an entire drive, *including* the operating system, then you must use a scrubber ala Cybercide. Is this an accurate understanding?
I realize Ive asked a number of questions here, but my choice of secure deletion program is extremely important to me--I want to make it once, and then simply commit to my chosen program, hopefully for many years, if not for life. And I dont doubt that others would be enlightened by this information, also. This is a complex decision.
Accordingly, Good Admin, complete, accurate answers to all questions will be extremely appreciated. Thanks.
Regards,
vincent christopher
- files/folders, or
Regards,
vincent christopher
