I am completely new to this subject. About 2 weeks ago, I found and downloaded Eraser 5.3. It seems to work properly for me. I just learned about version 5.6. If I am reading the website and posts here correctly, the improvements in 5.6 are primarily for compatibility with windows XP. Are there any advantages or improvements that would affect performance with Windows 98, which Im using? I noticed in the forums the problems that some people were having. Since 5.3 seems completely compatible with my old unit, I have hesitated to upgrade. If someone could advise me on this,(in slightly less technical terms than some of the posts use) I would very much appreciate it.
Rick
Rick
