Anshu_123
Using the MacSonik CSV to vCard Converter, you can convert CSV contacts to vCard (VCF) online. This software gives you an amazing option of multiple vCard saving options that allow you to create a single file for every contact. The Date range feature of this tool allows users to select the start and end dates to export the emails between them. Moreover, the tool allows you to navigate the desired destination path to save the vCard files. Users can define the saving location of VCF files as per their choice and preference.
