Best EDB to PST Conversion Software
SysOZ EDB to PST Converter is the only software which can provide the results in various formats like PST, EML, MSG and HTML which include inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (to, cc, bcc, subject, date and time). This utility is designed in a way that it retains the integrity of data after the conversion of Outlook EDB file. This application supports live Exchange Server 5.0, 5.5, 2000, 2003, 2007, 2010, 2013, 2016. You can avail the free demo version to convert 30 emails in each and every EDB folder free of cost given by this application. Use SysOZ EDB to PST Converter it is the most reliable tool in the market which provides each and very thing you want from the EDB converter. This converter support various files formats. This Exchange EDB to PST tool also supports cloud-based applications like Office 365 and Live Exchange Server. Not only this you can also directly export the recovered and converted data to Office 365 and Live Exchange Server. You can convert your data into various formats like EML, MSG, HTML and PST.
Read More: https://www.sysoz.com/products/edb-to-pst-converter.html
InQuit EDB Converter is one best tool to convert the EDB files in such a way that you can convert the EDB files in best possible way. InQuit EDB to PST Converter will recover the EDB files in formats like EML, EMLX, vCal, vCard, MSG, MBOX, and PST etc. You can also see the preview of the conversion and you can also split the large sized PST files in small bits as per your needs. You can also see the preview of the conversion and then you can look how this tool perfectly work. You can also split the large sized PST files in small bits as well. You can try the free demo version and convert 30 emails for free.
Read More: https://www.inquitsoftware.com/en/pages/edb-to-pst-converter.html
