In my experience, I suggest one software named EDB to PST Converter provided by SysInspire software to convert EDB to PST using its best techniques. The best part of this tool is you can export EDB file to PST and split it into many PST files without installing Exchange Server. You can also, convert EDB files into multiple formats such as MSG, EML, EMLX, & HTML without any data damaging.
If you worried about this software so try its FREE DEMO VERSION which can help to convert EDB files and show the preview with all supported versions of MS Outlook & MS Exchange up to and Windows versions up to (-bit, &-bit).
Get Some More Info:- Convert EDB to PST
