Best EDB to PST Converter
InQuit EDB to PST converter is most safe and secure software by which user can easily recover damage or corrupted EDB file from the exchange server. It easily supports public and private mailboxes folder. Download this software and convert a large number of EDB file to PST without any problems. Its working process is best for the conversion process.
InQuit EDB Recovery key feature
* Easy to support saving recovered EDB data into multiple file formats like EML, EMLX, MSG, vCard, vCal, MSG, MBOX and PST file formats.
* Recover emails from EDB file including Emails, contact, calendar, journal task, drafts, notes, deleted items, and attachment etc.
* This EDB Recovery software is provided a superb way to recover and save multiple mailboxes into PST file with Office 365 and Live Exchange server.
* This software successfully supports all Exchange server versions 5.0, 5.5, 2000, 2003, 2007, 2010, 2013 and 2016
* The users can split a large file into a smaller one as per their requirement
* It gives the option to see a preview of recovered mailboxes before conversion.
* It gives the option to convert 30 emails item per folder of EDB to PST file free of charge.
Read more: http://www.inquitsoftware.com/en/pages/edb-to-pst-converter.html
EDB to PST Converter preview of recovered mailboxes before conversion.
Now you can easily and safely convert EDB to PST with the help of Shoviv EDB to PST Converter Software. This Software has a feature of migrating EDB data to Office 365 and Live Exchange Server. Shoviv EDB to PST Converter Software also has a free trial version and good technical support team.
Exchange EDB to PST Converter that recovers the data and convert into Outlook PST and other file formats such as EML, MSG, EMLX, MBOX, vCal, vCard, HTML according to your requirement. It supports the version of MS Outlook 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019. With the aid of this program, you can convert Pub1.edb and Priv1.edb directly into cloud-based application Office365 & Live Exchange Server in a little moment. It gives a free demo version that allows you to convert 30 emails per folder free of cost. If you are not satisfied with this utility so you can return it within 30 days without facing any difficulty.
Read more info: https://freeexchangeedbtopstconverter.blogspot.com
ATS EDB To PST Software easily recovers all the flaws of the EDB file without applying traditional method. It individual tool is also capable to convert EDB data into Outlook PST data file.it designed professionally to convert EDB data smartly. It can divide your large OST file into several small PST file format. With the help of this program, you can easily handle encrypted file easily. This utility supports multiple file formats such as PST, EML, EMLX, vCard, vCal, MSG, and MBOX. It automatically scans all the errors and removes them instantly. Given 30 days money back guarantee.
Read More Info: https://www.bulkecommerce.com/store/edb-to-pst-converter-software-198.html
By getting the best eSoftTools EDB to PST Converter Software user can easily remove all errors from an important EDB file. This free EDB to PST Software allows the user to export the EDB mailbox items from both private and public folder to Outlook PST without any problem. It shows a live preview of the internal structure of Exchange EDB file before starting the conversion process from the EDB to PST. The software comes with a free trial version which is able to Export 30 items from each folder of Exchange EDB to PST.
Get More Info: https://www.esofttools.com/exchange-edb-to-pst-recovery.html
