gomesruiusa
SysOZ EDB to PST Converter is one of the best Exchange Server Recovery software which is use to convert the EDB data into PST, you can also convert the data into various other formats like Outlook PST, EML, MSG and HTML. This Exchange EDB Converter software can help you to directly export the data to Office 365 and Live Exchange Server as it can also support the cloud based application. It is possible to see the preview of the conversion with the help of this tool, to check how the final result will look. With the help of this Exchange EDB to PST tool you can do the selective conversion as per your need. This tool is one of the most trusted tool in the market most of the IT Person and big business houses use this tool. With the help of this tool you also split the PST files into smaller bits from 1 GB to 5GB. There is no size limitation you can convert the files of any size there will be no issues. This tool is compatible with all the latest version of MS Window and MS Outlook. This tool will safely recover the inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (to, cc, bcc, subject, date and time) and there will be also no data loss. You are free to try the free demo version of this tool with the demo version you can convert the 30 emails of each folders.
Read More: SysOZ EDB to PST Converter
