What is the best method to clean a whole drive using eraser. I have replaced my drive with a new one. I have intalled the OS on the new drive, installed it as the master, move the old drive to a slave postion and moved all information I need over from the old drive to the new drive.
I have to return the old drive as it was defective so I want to clean everything, including the OS installed on it the most secure way I can (short of distroying it).
I have selected all files, all directories on this old drive and and have used eraser to clean them (using Gutmann). I will then do the low level format with WD Lifeguard (I assume that is the write 0's option) that was pointed out here on the forum, My thoughts are to then go back over and clean all unused (that should be the full disk after the erase as noted above) with Pseudorandom.
My questions: Because I selected all files and directories I assume there is still information on the drive because of the boot recrods and other system information on a drive, how can I erase that so there is NOTHING left on the drive. Does the low level Lifeguard take care of that?
Also, after I clean all unused space, my thoughts were to re-format the drive. Will that help? Hurt? Make any difference?
What else can / should I do that I am missing here before I sent the drive back?
Thanks
Mike
Thanks
Mike
