Best Methods to Convert MSG to TXT without Outlook
If you need to convert MSG files to TXT without using Outlook, there are a couple of methods available.
Manual Method to Convert MSG to TXT
You can manually open and save MSG files as TXT without Outlook using the following steps:
  1. Use Notepad or Any Text Editor:
    • Right-click on the MSG file and choose Open With > Notepad.
    • The file will open in raw format, and you can extract the readable content.
    • Save it as a .txt file.
  2. Use an Online Converter:
    • Several online tools allow you to upload an MSG file and download it in TXT format.
    • However, this may pose privacy risks if your MSG file contains sensitive data.
Automated Method: DRS Softech MSG Converter Tool
For a hassle-free solution, the DRS Softech MSG Converter Tool allows you to convert MSG to TXT without Outlook in a few clicks. It ensures accurate conversion, preserving email formatting and metadata. Additionally, this tool supports batch conversion, allowing you to process multiple MSG files at once. Unlike manual methods, it prevents data loss and offers advanced features like email preview and selective conversion.
If you need an efficient and secure way to convert MSG files to TXT, DRS Softech MSG Converter Tool is the ideal choice.
