Shoviv Lotus Notes to Outlook Converter tool is the most excellent option for a solution to switch NSF to PST. It provides the best facilities to convert the multiple NSF data to PST and exports data into EML and MSG formats. The tool also provides the Filter and split options. The Filter option uses to filter the unwanted data and Split option helps to divide the large data files to small files. Shoviv Lotus Notes to Outlook converter run in all versions of Lotus Notes, Outlook, and Windows OS. It provides the free trial version of the tool which helps users test the tool and convert the first 25 items per folder without any cost.
More details, visit:- NSF to PST converter
