eSoftTools Software presents the best NSF to PST Converter Free tool, according to experts' reviews. It allows users to export Lotus Notes data to a variety of file formats, including EML, Yahoo, EMLX, HTML, MSG, Gmail, Zimbra, ICS, Office 365, PST, and several others. The demo edition is fully free and includes all of the software's capabilities, as well as the ability to convert the first 25 objects from each folder to MS Outlook 2000, 2016, 2013, 2010, and all previous versions.
Get More Info:- Export Lotus Notes data into Outlook PST
johnsheno
If you want the easy and accurate conversion of Lotus Notes to Outlook. I would Suggest SYSessential NSF to PST Converter tool. The tool provides the best and fast services. It successfully exports emails, messages, calendars, contacts, to-do lists, tasks, notes, etc to a new PST file at a user-defined location. If you have multiple NSF database files saved in archive format, you can select all of them and perform their batch conversion in just a single conversion process.
You can save enough time by using this SYSessential third-party application and trust me, you will not regret using the application.
Lotus Notes and MS Outlook both are an email customer that supports diverse file formats for saving information. In any case, now and then NSF file gets out of reach because of an obscure explanation. In the present circumstance, the client needs to change the whole information from NSF over to PST file format. ATS NSF to PST Conversion programming is an ideal application for this undertaking. Utilizing this utility you can see the recuperated mailbox before the conversion. It effectively imports the allover information from NSF file to PST and other file formats like PST, EMLX, EML MBOX, MSG, HTML, CSV, vCard, vCal without confronting any trouble. It support Lotus Notes version 9.0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5 and 6.0.
