For the better conversion of Lotus Notes NSF to PST Outlook, Try the best third-party conversion tool - Shoviv Lotus Notes to Outlook converter tool. Using the Shoviv NSF to PST converter tool there is no requirement of an expert, the user interface of this tool is very easy to use non-technical user use this tool is very easy.
With the help of this tool, you can take the following advantages
- The tool migrates multiple mailboxes to PST in a single attempt.
- It converts multiple mailboxes and also saves in EML, MSG, HTML formats.
- Provide high-speed conversion process.
- Provide a filter facility.
- Supported by all versions of Lotus Notes, Outlook, and Windows OS.
- For the demo purpose, you can download its free trial version to check all features and migrate the first 25 items per folder.
