Best OST to PST Converter- Expert Suggested
OST to PST converter easily converts Outlook OST files to PST format. The conversion is necessary when users need to transfer their email data from one computer to another, import data into an email client, or archive their emails.
Features of the Best OST to PST converter include:
  1. Batch conversion support to convert multiple OST files to PST in one go.
  2. Support for all versions of Outlook including Outlook 2019, 2016, 2013, 2010, and others.
  3. Option to preview and select specific emails, contacts, calendars, and other items for conversion.
  4. Ability to preserve email attributes, such as email headers, formatting, and attachments.
  5. Option to split large PST files into smaller ones to avoid data corruption.
  6. Support for encrypted and password-protected OST files.
  7. Easy-to-use interface, even for non-technical users.
Note: It's important to choose a reliable and secure OST to PST converter to avoid data loss and potential security risks and this utility is best solution for you.
OST to PST is an extremely popular conversion, so there are a lot of tools and manual methods available for this conversion. Here, I would like to recommend a blog's manual methods that can convert OST files to PST and also save you money. There are four different free solutions that are more advanced and effective for moving OST data to the PST file. Users can use these solutions based on their needs.
  1. Using export feature in Outlook
  2. Archiving OST data to a PST file
  3. Run the manual archiving
  4. Drag and Drop into a new PST file
To know more, you can check : 4 Free Methods to Convert OST to PST File Format
Use SysVita OST to PST Converter to convert OST files between various file formats. The best software for migrating OST files to AOL, Gmail, Yahoo Mail, Office 365, and Thunderbird is this one. When you convert once, you can add multiple files at once. Because of its straightforward user interface, OST file migration can be completed by anyone, regardless of their level of technical expertise. works with all Windows OS versions.
more Info: Free and Best Outlook OST Recovery Tool - SysVita Data Recovery
