Best Solution to Convert MBOX to PST
I had trouble converting MBOX files until I found this simple tool. The MailConverterTools MBOX Converter helps users to convert MBOX to PST, EML, PDF, and TXT. One great feature is the preview option, which lets you check your emails and attachments before converting. The interface is clean and easy to understand—even if you’re not a technical person. One of its key features is that the software ensures data integrity during the conversion process. It safely converts emails without overwriting the original MBOX files. Instead, it creates a new file, keeping your original data completely safe and unchanged. Apart from this, the software lets you exclude attachments from emails while converting or backing them up. You can also choose to save multiple MBOX files into a single PST file if needed.
