Best SQL Database Recovery Tool to Recover Corrupted SQL Database
Khushi Singh
SQL Server databases often encounter issues like corruptions and other errors that affects the database accessibility and privacy. In such cases, it is crucial for the users to choose a reliable solution like the SysTools SQL Database Recovery Tool, can be helpful for them. This utility is specially designed to repair and recover SQL database files from corruption and other errors. Furthermore, the tool allows users to recover various database objects such as functions, views, triggers, stored procedures, etc. Hence, with the help of this solution, users can effectively repair their databases and secure their data in a much efficient way.
Important Note: Download the Free Version Now to Recover First 25 Records.
How to Recover Corrupted SQL Database?
  • Step 1: Launch the tool and add the corrupted MDF/NDF file.
  • Step 2: Select Quick Scan or Advanced Scan based on corruption level.
  • Step 3: Enable the option to recover deleted records if required.
  • Step 4: Preview all recovered database objects in the interface.
  • Step 5: Choose to export into Live SQL Server or as SQL scripts.
  • Step 6: Select desired objects and configure export settings.
  • Step 7: Click Export to complete the SQL database recovery.
Top Features of SQL Database Recovery Tool
  • Repairs MDF & NDF Files – Recovers both primary and secondary database files affected by corruption.
  • Recovers All SQL Objects – Tables, triggers, views, functions, rules, stored procedures, indexes, keys, etc.
  • Dual Scan Modes – Quick Scan for minor corruption and Advanced Scan for severely damaged databases.
  • Previews Recoverable Items – Allows users to check recovered tables and data before export.
  • Supports All SQL Server Versions – Compatible with SQL Server 2000 to the latest releases.
  • Exports in Multiple Ways – Restore directly to a live SQL Server environment or export to SQL scripts.
  • Recovers Deleted Records – Specialized option to retrieve data that has been accidentally deleted.
  • Maintains Data Integrity – Preserves schema, relationships, and original data types during recovery.
  • User-Friendly Interface – Simple GUI suitable for both admins and non-technical users.
