Best SQL Recovery Tools of 2025
The DRS Softech SQL Database Recovery Tool is the most efficient software that can recover your MS SQL data. It recovers your SQL database objects like tables, indexes, and tablespace to their original positions in a matter of a little time. You can also export data in CSV and restore it in snapshot mode.
This software has an advanced and safest way to restore corrupted database in SQL server. It does not retain or pass any part of data while recovering the data. Moreover, the utility is malware-free.
Exceptional Features of the DRS Softech SQL Database Recovery Tool
- This tool requires minimal time to recover the corrupted MDF and NDF files.
- In addition, it can also repair full MS SQL database objects such as tables, views, indexes, and many more.
- Additionally, it possesses a collation option through which users can select auto-detect and Manual detection in order to maintain databases of different languages.
- You can restore repaired data directly into the database and download the recovered CSV files script on your system.
- Non-technical users can operate this software without any difficulty since it provides 24*7 technical support.
- There is a demo version to test the paid tool.
- In addition, it is compatible with Windows 11, 10, 8.1, 8, 7, Vista, and XP.
- Moreover, this tool has great reviews on Trustpilot.
