Best successful vMail OLM to PST Converter application
Jonasnick
Get successful vMail OLM to PST change Software. These application just products every one of your messages, contacts and schedules from Outlook for Mac OLM records to MS Outlook PST documents. It is a high level email converter created by converter specialists. The product can change over various OLM documents to PST records in a flash. This product insightfully changes messages over to Office 365, MBOX, MSG, EML, HTML, Gmail, PDF, and so forth
Know more info- vsoftware OLM to PST Converter
Danish
There is also a manual solution available which you can prefer to convert OLM to PST files. Follow the given below steps:
  • Create an IMAP account
  • Configure Outlook for Mac with an IMAP account
  • Export Outlook for Mac emails to the IMAP account
  • Configure Outlook for Windows With the same IMAP account
AnkitAryson
If you would like to convert Mac OLM files to PST then as a user I suggest a professional Mac OLM to PST Converter Tool. It is a near-perfect and most reliable solution to export OLM to PST files on Mac with a professional OLM Converter Tool for Mac. It allows the users to perform bulk conversion and maintains high data security and integrity throughout the process.
You can follow the steps accordingly to save OLM as PST,
  • Download and Launch MacSonik OLM Converter Tool on Mac.
  • Press the Browse button and choose single/multiple files then click on Open.
  • Select OLM files from the tree folder and press Next.
  • Select PST from the Migrate as option and click on the Convert button to start the conversion.
In case you are searching for an advanced and reliable software utility to perform OLM to PST Conversion then it is a smart choice to compare the performance different utilities available online. It will help you to opt for the best-performed utility according to your purpose. One of my colleagues has been using the Cigati OLM to PST Converter for this purpose. He is well satisfied by its performance. Apart from the assurance of data security, this utility has some more advanced features that enhance and optimize its overall performance. In case you are still searching for the best converter tool then you can try its free trial version to analyze its performance.
facoc57
You can convert the Mac Outlook OLM file into a PST file for Windows Outlook using OLM to PST Converter Tool. This software helps you can convert OLM files of Mac Outlook 2016, and 2019 format to PST format. It migrates all data items like emails, contacts, calendars, notes, tasks, journals from OLM to PST format. It also lets users perform selective data migration from Mac Outlook to Windows Outlook. In addition, the software is available for Windows and Mac OS versions. It has brilliant and enhanced user friendly interface to make this application fast and simple. Use this free trial version of this app to understand it function and features.
OLM Exporter Tool is the best solution for converting OLM files into PST. It is the most perfect and reliable solution that can convert OLM files into PST, MSG, MBOX, EML, and EMLX file formats. It also converts OLM files to different file formats like PST, MSG, MBOX, EML, and EMLX. you can use this tool in any version of Windows OS and convert your OLM files into PST. With Free Demo Version, you can export only 10 items to each folder without any cost.
Visit here for more info: https://www.betavare.com/olm/
GainTools OLM to PST Converter Application can absolutely support to the advance version of Outlook 2019 and all the below versions of Outlook for both 32-bit and 64-bit Windows operating system. In the demo version, users can perform the conversion of 10 items from each folder of Mac OLM files into Outlook PST format.
At the end, users will get their entire emails at similar folders and sub-folders without switching any information. It can be completely handled by any non-technical user to perform the conversion procedure in few seconds. The intuitive interface of the software can be smoothly understandable for users to perform the conversion procedure.
