Best utility to Convert NSF files to Outlook
Effective solution to convert NSF files to Outlook without affecting the original data of the Lotus Notes file internal data is by using eSoftTools NSF to PST Converter Software that maintains the original folder data structure and allows you to convert multiple files in single go. It gives you the facility to export NSF files in various file variants PST, MBOX, EML, EMLX, CSV, etc. No need of MS Outlook installation and you can also split the large size NSF files into multiple PST files. By using this too, you can use date range filter through which you can search the specific location of the NSF file and locate them through date range filter feature. It is completely compatible with all the editions of MS Outlook upto2016.
Get more info: NSF to PST Converter
I had a solution for the migration problems of the data from Lotus Notes NSF files to Outlook PST format which is the gamer changer for any user facing conversion issues. You can follow this NSF to PST Conversion guide to have an accurate conversion for the data.
If you are searching the best Utility for Lotus Notes NSF data to Outlook PST Conversion, users must try the Shoviv Lotus Notes to Outlook Converter tool. The tool provides the best and fast services. It helps to convert accurate NSF data to Outlook PST at the same time without any data loss it provides the guarantee to convert accurate data without any error.
Some Special Features of the tool:-
1:- Provides Fast, secure and Error-free conversion
2:- The tool convert Bulk NSF data to Outlook PST at the same time
3:- Export NSF data to EML and MSG formats
4:- Provides Filter, Mapping, and Split options
5:- Support all versions of Lotus Notes, Windows OS, Domino Server, and Outlook
6:- Download its free trial version and convert the first 25 data items per folder.
More details, visit:- NSF to PST Converter
