Best Way to Export AOL Emails to PST
Anshu_123
Are you struggling to export your AOL emails to PST for Outlook? Whether you need to back up your emails, switch from AOL Mail to Outlook, or ensure secure email migration, finding the right solution is crucial.
While AOL does not provide a direct option to export emails to PST, you can use a professional tool like Cigati AOL Backup Tool to get the job done quickly and efficiently. This software is designed to export AOL mailboxes to various formats, including PST, MBOX, EML, PDF, and more, without losing any data.
Step-by-Step Guide to Export AOL Email to PST
Follow these simple steps to back up your AOL mailbox:
Step 1: Download and install Cigati AOL Backup Tool on your system.
Step 2: Open the software and log in using your AOL email credentials.
Step 3: Select PST format from the list of available options.
Step 4: Choose the AOL email folders you want to back up.
Step 5: Apply filters if you want to export specific emails.
Step 6: Select the destination path to save the PST file.
Step 7: Click Convert and wait for the export process to complete.
Once the process is finished, you can import the PST file into Outlook using the Import/Export Wizard (File > Open & Export > Import/Export).
Exporting AOL emails to PST is effortless with the Shoviv IMAP Backup and Restore Tool. Follow these steps:
  • Step 1: Download, install, and open the Shoviv IMAP Backup tool.
  • Step 2: Click "Add" enter your AOL IMAP credentials and create a backup directory.
  • Step 3: Choose the specific folders or emails you want to export.
  • Step 4: Select PST as the output format for the backup.
  • Step 5: Specify the location to save the PST file.
  • Step 6: Click "Backup" to begin the process.
Read also - https://www.shoviv.com/blog/export-aol-email-to-pst/
