smithjones24
If you want to fix Outlook Search Not Working on Mac, there are a couple of things you can try to resolve the problem. These methods are completely free and require no further tools to correct the problem. All you need is basic technical knowledge. First, you need to identify the nature of the Outlook issue. From there you can decide which method of resolution to use.
1. Deleting Outlook Account Then Adding It Again.
It is possible that your Outlook profile is the reason as to why the Outlook search is not finding all emails. If this is the case, we should delete the Outlook account then add it again. It is worth deleting the account if prevent all issues caused from a corrupt Outlook profile.
1. Locate and click on Finder Icon then open Applications
2. After this choose the Microsoft Outlook option.
3. Now click on Show Package Content. This will open all packages of Microsoft Outlook.
4. Click on Content folder then click on SharedSupport folder. Finally, click on the Outlook Profile Manager.
5. You should see a wizard called Outlook Profile Manager. Select an Outlook profile of your choosing then select the Remove icon.
6. A pop up will appear asking for your confirmation. Click Dlete. Great the Outlook profile has now been deleted.
7. Next, click on the add icon to re-add your Outlook profile.
8. The default name of the profile is Profile 1. Change it to a name of your choosing.
9. Launch the Outlook app, and then click on Outlook Settings.
10. Choose Account and then click on the + icon, and then, click on the New Account button.
11. Now you will enter all the required details to create your Outlook profile.
Do you want to avoid data loss while using Outlook? The best practice is to back up your mailbox data regularly. This will protect your valuable data from loss. Now, what is the best method to back up your Mac Outlook mailbox?
The MacSonik OLM File Converter for Mac is the most efficient and secure utility that can convert your Outlook OLM files to a separate file format and transfer your Outlook data over to a separate piece of email. If you are planning to back up your Outlook data on another device, converting the Outlook OLM file to a usable file format would be helpful. The tool will provide many services to assist with file conversion.
