graham2020
If you are seeking the best way to Import your MBOX data to Outlook PST. You can go with this smart MBOX to PST converter tool which is the most advanced feature software that is present on the internet. It supports converting more than 17 email clients of MBOX format to Outlook PST, PDF, HTML and RTF. It can also migrate MBOX mailbox data directly into Office 365 mailboxes. The tool is compatible with all versions of MS Outlook and Windows OS. For more details, visit:
https://www.datarepairtools.com/mbox-to-pst-converter.html
