smithjones24
I recommend using the MailConverterTools PST Viewer to view and open PST files without Outlook. The software does not require the Outlook application to open, view, or read PST files. Using this top-notch utility, users can convert PST to MBOX, MSG, CSV, EML, and HTML. Additionally, it supports PST files from all Outlook versions. You can open password-protected PST files, even if you're unable to recover them. The software is a Windows-based utility and works on all major versions of Windows Operating Systems. Moreover, this tool has no size limitations, allowing you to open large PST files and view corrupt PST files without any data loss.
