Best Way To Repair And Recover OST Files
Convert the data from Outlook OST to PST by taking the help of OST to PST Converter tool. The tool is designed with the best technology that make the conversion process smooth and reliable. You can export single as well as multiple features that make it easy to use. The algorithm of the program is advanced. Hence, you can operate the program without any technical skills.
Through the help of this utility, you not only recover the data but also convert into new Outlook PST file format without losing any information. It breaks mega OST files into several small PST files according to your needs. Before the conversion process, it will show the preview of the recovered mailbox and also make changes in the database but only before the conversion.
The user migrates single as well as multiple files at a onetime along with email, inbox, outbox, contacts, deleted items, drafts, calendars, sent items, notes (to, cc, bcc, subject, date and time). It supports PST, EML, EMLX, MBOX, vCal, vCard, HTML, MSG file formats to collect the final result after the conversion.
Read More Info: Convert Outlook OST File To PST
Free Download Software with Softonic:
https://ats-ost-to-pst-converter-toolkit.en.softonic.com/
Free Download Software with Cnet:
http://download.cnet.com/OST-to-PST-Converter/3000-2369_4-77530261.html
Try this eSoftTools OST to PST Converter without any problem in the conversion of the OST files in minutes. The best solution to change the file format with all the items of files. It allows the users to export the OST files in bulk. This utility can scan the OST file and capable to export these encrypted emails to PST format without any modification of the information. It migrates all the meta properties and data.
To Know More:- Free Unlimited OST to PST Converter Tool
