If you're searching for a top-notch process to migrate Outlook emails from PST to TGZ format, then EmailSoftwares Outlook to Zimbra Converter is the solution. The program enables you to convert both ANSI and UNICODE PST files to TGZ files, which are Zimbra-supported, without any installation of Outlook or Zimbra. The original folder structure, formatting, and email information are all preserved, providing for a seamless migration. It works with large and password-protected PST files with flexible conversion parameters. The non-technical person can also utilize it with its easy-to-use interface. Have a trial for free to understand its capabilities and then purchase the full version.
