CDR Converter
Anshu_123
MacSonik CDR Converter is a top-notch utility that helps you to convert CorelDraw files to different image formats like JPEG, PNG, PDF, GIF, etc. It is capable of converting any size of CDR file into the desired image formats. This software gives you a preview of CDR files that allows you to view the size and destination path of the selected CDR files before the final conversion. Moreover, the software supports CDR files from all versions of CorelDRAW.
