Comment Convertir un fichier EML en fichier PST ?
Aloraeve
Essayez l'outil de conversion Advik Convertisseur EML en PST Windows. Le logiciel convertira sans effort vos multiples fichiers EML au format PST sans aucun problème. Essayez la version démo du logiciel pour connaître son processus de fonctionnement.
Étapes pour convertir EML en fichier PST
1. Exécutez le logiciel sur votre système.
2. Ajoutez les fichiers EML.
3. Choisissez PST parmi les options proposées.
4. Parcourez l'emplacement ciblé et appuyez sur le bouton Convertir.
Fait! Terminez ici le processus de conversion.
If you want to change EML file to a PST file, the best approach is to use a conversion tool that able to manage the process without losing your email content. You must utilize this tool that can read EML messages and recover them into a PST file. One of the great choice for this task is the Softaken EML to PST Converter. It lets you load a whole directory or individual EML files and transfer them into PST format. The tool preserves your attachment folder structure and formatting so nothing gets altered. Once the conversion is finished, you can launch the PST in any kind of Microsoft Outlook. Simply install the program, include your EML files, select PST as the output, and start the conversion—rather simple.
If you're looking for an automatic way to convert EML files to PST file format, give the ZOOK EML to PST Converter .Users can export their EML emails' many attachments in PST file format. For the EML to PST migration, users didn't need to download any additional apps. The program gives a preview option before beginning the conversion. This utility can convert EML files to PST file format for both professional and non-professional users. Users may save their transformed data with this application wherever they like on their PC. This utility works with both the most recent and the oldest versions of Windows.
