Context Menu Problem : Windows XP SP3 and Eraser 6.07.1893
DaddySam
I have installed Eraser 6.071893 and it works fine.
Integration into Windows Explorer is also fine.
However I have a problem with a Windows Explorer similar program called "Magellan"
Magellan works same as Explorer for all aspects including Shell Integration.
For Eraser, the Context Menu in Magellan shows a blank line where "Eraser" should appear. However the Submenu of 2 items is there (same as in Windows Explorer)
Please note this unusual feature of the Context Menu did not appear with previous versions of Eraser which behaved properly in both Windows Explorer & Magellan
There must be a way to correct this situation
Can somebody help
With thanks
samazar@hotmail.com
Re: Context Menu Problem : Windows XP SP3 and Eraser 6.07.18
This is possibly caused by an error in the way Eraser deals with Context menu messages. Please file a bug in Trac so I can fix this later.
Fixed in r2253 and r2254.
At this moment, 2252 is the most recently posted build, though the change log goes up to 2258.
Looks like SF had some issues. Wait for the next build this afternoon.
