Convert EDB files into Outlook
alex786
Here is a reliable and secure solution to convert EDB files into Outlook PST. Shoviv EDB to PST converter software facilitates converting Exchange EDB files to Outlook PST with excellence. There is no restriction on the number and size of the EDB file to be processed at once. This efficient software comes with complete data protection during the entire conversion process.
It provides complete recovery of EDB files before conversion; it also gets the item back from hard deletion. Users can split the resulting PST database into multiple smaller PST files at a specific size by using the Split option. It allows an enhanced incremental export option that resumes your interrupted exports and prevents duplication. The Item Filter option of this tool enables users to transfer desired data from EDB files by date range and message class (message type).
Before investing, one can evaluate its advanced features to convert EDB files into Outlook PST.
You can use the Softaken EDB to PST Converter, which allows users to convert EDB files into Outlook PST format without installing Outlook. This tool is best for converting all data, such as emails, contacts, notes, journals, calendars, events, and other data, from EDB to Outlook PST format without any technical errors. You can use this software with simple technical skills because it has a simple graphical interface. Technical expertise is not necessary. The Exchange EDB file data is converted to PST file format without any limitations. It supports work with MS Outlook 2021, 2019, 2016, 2013, 2010, 2007, etc. are supported by the software. You can install this software on Windows OS with a free trial version to convert a few EDB files to PST for free.
