dianastubbs
EDB to PST Converter Software gives conveniences to recover damage or corrupted EDB files from exchange server database with all emails item and convert them into PST files and other formats like PST, MSG, EML, vCard, vCal, MBOX and EMLX and vCard without any failure.With this program user can quickly extract entire data from EDB file into new working PST file formats.
Download EDB to PST converter software which provide facility converts EDB files into PST and other variety of formats by following easy steps. It allows that during conversion process you can split outsized PST into small PST size upto 5GB as well as auto detects .edb missing location.
EDB to PST Converter Software shows you the preview of how it convert EDB mailbox to PST, this options makes you satisfied about the working process of the software. Export EDB file to PST is well works on all Exchange server versions 5.0, 5.5, 2000, 2003, 2007, 2010, 2013 and 2016.
Download link :- http://www.filesrepairtool.com/edb-repair-tool.html
