Convert Lotus Notes data to Outlook Using NSF to PST converter
Shoviv Software is a popular name in the field of Lotus Notes to Outlook converter. Shoviv Lotus Notes to Outlook converter provides a genuine way to migrate Lotus Notes data to Outlook PST with an error-free conversion. its user interface is very easy to use any non-technical user use the tool very easily and converts the data.
Some highlights of the tool
1:- Perfectly expert to convert multiple Lotus Notes data to Outlook PST.
2:- Save data into EML, MSG, HTML formats.
3:- Provide Mapping option
4:- Available Filter option, It helps to filter unwanted data
5:- Also available Split option
6:- Compatible with versions of Lotus Notes, Outlook, and as well as Windows OS
More details, visit:-
NSF to PST Conversion software is a flawless solution to Convert Lotus Notes NSF mailbox to MS Outlook PST. The utility performs NSF File to PST converter in a very easy to use. It converts all NSF emails items like contacts, calendars, tasks, journals, notes, emails properties and attachments to PST format, This tool is compatible with Windows versions 95/NT/ 98/2000/ XP/ Vista/7/8/8.1/ 10 and MS Outlook 2000, XP, 2003, 2007, 2010, 2013, 2016.
More Info:- NSF to PST Conversion
Use NSF to PST Conversion the great utility as this seems to be quick utility for me when. NSF to PST by exporting all your emails, calendars, journal, tasks, etc. Free Trial version which Transfer the first 10 items from each folder. NSF file into PST without facing any kind of problems. This tool Supports NSF versions 6.0, 6.5, 7.0, 8.0.2, 9.0, and 9.0.1. This Software Supports MS Office 2003, 2007, 2010, 2013, 2016 and 201
The way which is advised to convert Lotus Notes to Outlook is by using software like eSoftTools NSF to PST converter tool. This software has the ability to export NSF file into several file formats such as PST, EML, EMLX, HTML, MSG, vCard, etc. The hierarchy of the folders and subfolders remains the same after NSF file recovery. A demo version is also provided to each user to test the performance. This tool is compatible with all variants of Lotus Notes and Outlook.
Explore more about NSF to PST converter here.
Users who want to convert data from the Lotus Notes NSF format to the Outlook PST format can make use of the Softaken Lotus Notes to Outlook Converter tool. It allows users to export entire NSF file data, including emails, notes (to, cc, bcc, subject, date, and time), to Outlook PST. You are given permission to view the mailbox preview prior to conversion. Additionally, it exports data in MSG, HTML, and EML formats. To test out all the features and functionality, as well as migrate the first few items to each folder, download the demo version.
Using a smart tool like SameTools NSF to PST Converter Software is the method that users have tried to convert NSF to PST files. It is user-friendly and enables exporting of all mailbox elements, including emails, notes, calendar items, notes, contacts, etc. The user can keep the data without altering the directory's order. The user can also see the entire process and how the software functions on their screen. It can be tested without cost and is compatible with all versions of Outlook and Lotus Notes.
