convert pst to mbox thunderbird
camilia
Generously convert all large MS Outlook files and folder without any size limit with the assist of PST to MBOX Converter Software that provides multiple features facilities to fix errors easily.. The application advance programming offers to considerable platform to export MS Outlook files into 15+ multiple other file formats such as Live Exchange server, Zimbra, Gmail, EMLX, EML, MSG, Office 365, MBOX, PST Outlook , ICS, vCard and etc. without any limitation.
How PST to MBOX Converter Application Works?
  1. Download and Launch the Application of KDETools PST to MBOX software.
  2. Locate Outlook PST File.
  3. Preview Mode for Convert PST to MBOX Thunderbird.
  4. Choose Desired Export Type.
  5. Locate Output Destination Path.
  6. Step 1: Launch Tool and Add PST files.
  7. Step 2: Show Preview PST file.
  8. Step 3: Select Export Option for PST to MBOX file.
More Info- PST to MBOX Converter
To move the data form PST to Thunderbird you need to convert the data files from Outlook PST format to MBOX format and get those MBOX files imported into Thunderbird email client easily. To have a safe conversion from PST to MBOX format you can try the Softaken Outlook PST Converter software.
Don't trouble anywhere, just download the free Version of ATS PST to MBOX Converter Tool to check the working capabilities of this tool. It safely repairs damaged PST files and export single as well as multiple PST files into MBOX files, MSG, vCard, EML, EMLx, PDF, HTML, vCal, NSF file types without losing any existing mailbox data. This tool directly exports PST file into cloud-storage applications like Office 365 & Live Exchange Server.
These are available two types of Tool to Migrate or Convert PST file MBOX.
  1. PST to MBOX Conversion tool
  2. Outlook PST Converter Tool
Key Features About PST to Mbox Conversion tool:
  • PST to MBOX Conversion tool easily repair Corrupted PST file and Convert into MBOX file formats.
  • This Software Created multiple file-formats like MSG, EML, EMLX, MBOX, and HTML file types.
  • Created MBOX file support 35 emails Clients like Thunderbird, Apple Mail, Sea Monkey, and others.
  • This software available demo version tool to easily test to working or Not. The Demo version saves 30 email items in each folder.
Read More Info: ATS PST To MBOX Converter
About PST Converter tool
  • ATS PST Converter tool also PST Repair toolkit to repair Outlook PST file any versions.
  • This tool smoothly repairs corrupted PST files due to dirty shutdown, power failure, oversize, virus attack, etc, and convert into Outlook PST file formats.
  • Batch Converter option to Export multiple PST files to PST, MSG, EML EMLX, MBOX, etc files formats.
  • Restore PST files into Cloud Server As Office 365 & live Exchange Server.
  • Split large PST files to Small PST Files.
  • Easily Convert Outlook all versions of the PST file into MBOX file formats.
Read More Info About Outlook PST Converter
You can easily export your Outlook messages and other data to Thunderbird by converting Outlook data file (PST) into MBOX format using vMail PST to MBOX Converter Software. This software is capable to export all emails, contacts, calendar, tasks, notes, journals, attachments etc from any large size of PST file to MBOX file. There is no risk of data in pst to mbox conversion process using this software.
tomhayden
With the help of a professional GainTools PST to MBOX Converter Online, users can straightforwardly move numerous PST files to MSG, EML, MBOX, VCF, and EMLX, etc. This utility comes with so many astonishing and latest features for users.
