Convert Zimbra TGZ to PST Using Cigati Zimbra Converter
Anshu_123
Zimbra is a popular email client, but users often need to switch to Outlook for better compatibility and features. Since Zimbra stores emails in TGZ format, and Outlook supports PST, converting TGZ to PST is essential. The easiest way to achieve this is by using a reliable third-party tool like Cigati Zimbra Converter.
Why Convert Zimbra to PST?
  • Seamless Migration – Move emails, contacts, and calendars to Outlook.
  • Better Compatibility – PST is widely used in MS Outlook.
  • Offline Access – Access emails without an internet connection.
Steps to Convert TGZ to PST Using Cigati Zimbra Converter
  1. Download and install the Cigati Zimbra Converter on your system.
  2. Click on Add File and select the TGZ file you want to convert.
  3. Choose PST as the output format.
  4. Set the destination folder and click Convert.
  5. Once completed, import the PST file into Outlook.
Key Features of Cigati Zimbra to PST Converter
✅ Supports bulk TGZ file conversion.
✅ Maintains folder hierarchy and data integrity.
✅ Converts TGZ to multiple formats like PST, MBOX, EML, etc.
✅ Compatible with all versions of Zimbra & Outlook.
Final Thoughts
Converting Zimbra TGZ to PST is hassle-free with Cigati Zimbra Converter. Whether you're migrating to Outlook for business or personal use, this tool ensures a smooth transition without data loss.
Using a specialized tool like Softaken Zimbra to Outlook Converter is the most effective approach to converting Zimbra TGZ to PST format. With just a few simple clicks, this software can convert Zimbra TGZ files to PST, MBOX, EML, and other formats with attachments. Exporting Zimbra TGZ emails to PST files and other file formats with folders, structure, properties, hierarchy, and many other features in any size without any limitations or data loss is made possible by this tool. This professional tool works with both the latest and older versions of Microsoft Outlook and Zimbra Desktop. Additionally, both technical and non-technical users will find this conversion tool easy to use. Additionally, Windows 11, 10, 8.1, 8, 7, XP, and Vista can all download this Zimbra to PST converter. Additionally, users may test the tool's features with a free trial and convert emails from TGZ to PST format without any issues.
