CSV to vCard Converter
Anshu_123
With the help of MacSonik CSV to vCard Converter, you can easily convert CSV contacts to vCard. This utility Offers various vCard field mapping options between CSV and vCard. It allows you to convert CSV files to PDF file format. The software gives you an amazing feature to select the Desired Destination Path which enables you to navigate the desired destination path to save the vCard files.
