Testoronius
I want to see and save the contents of an erased file, to validate and compare different custom erasing methods. I figured I could use the XP command 'fsutil hardlink create', but seeing the contents after erasing, it looked like Eraser would always inject some pseudorandom .DLL code (to mask the erasing) and never will fill the file with, for example, only zero's.
Why isn't the erased testfile filled with 0's if my custom method consists of one pass of zero's?
How can I be sure that my custom method for files (not disk) is being used, if fsutil resistance is futile against The Erasing?
To explain a bit more:
Hardlinks act like pointers or hyperlinks to one and the same physical file on disk. Meaning the file would STILL be on disk if not ALL instances of the hardlinks were deleted. Altering the contents of by erasing (overwriting) one instance would automatically 'parse' the new data to the physical file. This way I can open files in my Hex editor after erasing them.
Reproducing the problem:
Thanks for replying and thank you Joel for this great and indispensable privacy tool .
PS: I know I can easily zeroing a file out in Hex Editor, but that's not my point.
PPS: I'm using Eraser version 8.5.5 and can not be convinced to upgrade to any higher version that requires the awkward .NET framework.
- 1. In Command prompt window:
Code:
echo>c:\testfile_a.txt fsutil hardlink create c:\testfile_b.txt c:\testfile_a.txt fsutil hardlink create c:\testfile_c.txt c:\testfile_a.txt
- 2. In Eraser GUI:
- Erase c:\testfile_b.txt with custom method of one pass of zero's.
- 3. In HxD editor:
- open file c:\testfile_a.txt as readonly
open file c:\testfile_c.txt, select all and fill with zerobytes
compare both files and see the difference.
