Custom Pattern
  • Start date Start date
Hi,
I've been using Eraser and it's been quite good!
There is one thing i've been trying to do though, customising the pattern used in overwrites. While configuring erase options let's you pick the number of passes and whether you want random numbers or not, you can't change the '0000..' part of the text boxes.
Is this only my install, or is it a program limitation of sorts?
You can, it just doesn't act like a normal text box.
1) You can't delete, backspace, or otherwise "blank" the text box.
2) It only accepts 0's and 1's (binary) input, so USUCK000, 1BADCAFE, or FFFFFFFF won't work.
-neoaeon
