Does Eraser Uninstall "erase" Eraser?
Nagaboto
Having used Eraser to clean up unreserved space on my hard drive, it would be useful if forensic examination of the hard drive did not show that the eraser program was used on the system connected to that hard drive. Does the uninstall routine do this, or will it be evident to anyone inspecting the unreserved space after the program is uninstalled from the system that it had previously been installed there?
Nope, uninstall works like a normal uninstall. If you want no traces, use the Portable builds. It would be nearly impossible to get the uninstall to erase after itself...
