does eraser work through LAN ?
fabianus
Hello!
Does eraser work through LAN ? I mean when I use eraser from Machine1 to erase a file on Machine2.
Thanks for any suggestion!
Regards,
Fabian
Hello guys,
I really need to know if the eraser does erase correctly if I shred a file through the local network (using eraser installed on machine1 and erasing a file that is shared by a machine 2).
Thanks a lot for any feedback !
Regards,
Fabianus
It most probably would. But your network administrator will not be to happy with you saturating his network.
