Deep Loner
I'm confused whether Eraser actually clears unused entries from the Master File Table or not.
This is taken from the website's FAQ:
Also, the help file says:
Yet this is the dialog box for erasing options:Erasing Unused Disk Space. What does that do?
Eraser will clean the unused parts of your disk. This will remove traces of any deleted data on the drive.
It will not remove deleted file entries these remail as 'ghosts' in the MFT/FAT.
Please clarify whether or not Eraser actually clears entries from the master file table, and precisely what the option in the dialog box is for.If you select "Free Disk Space", all available, or free, disk space will be overwritten. On Windows NT and 2000, the unused space on the Master File Table records will be cleared as well.
