Drag and Drop from Recycle Bin
spawarchs
Hi,
I am configuring Eraser for a customer, and he does not want the right click menu options (shell extenstions, I believe?) enabled. Why can't I drag files from the recycle bin to the task list? Is there an option to allow this? File chooser doesn't see the recycle bin either - same question.
Thanks,
Tom
Recyclebin = right click then choose erase
regsvr32 /u eraseext.dll
Garrett
"erasext.dll was loaded, but the DllUnregisterServer entry point was not found. This file can not be registered."
That's the message I got when I ran "regsvr32 /u erasext.dll"
What does it mean?
