DXL to PST Converter
DXL file or Domino Extensible Language file is an XML database file for which stores IBM Lotus Domino databases elements such as schemas, design elements, views, forms, and documents. IBM Domino and Lotus Domino Designer are only programs that can open DXL files. DXL to PST Converter Tool from V Software helps you in accessing data from DXL file in Microsoft Outlook by converting the file to PST format without losing any data.
This PST file is easily accessible in any version MS Outlook application. You can use this DXL file converter software to convert it to PST, EML, MSG, EMLX, MBOX, HTML file formats and also directly migrate data from DXL file to Office 365. vMail DXL to PST Tool supports DXL file from Lotus Domino software versions 9.0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5 and 6.0.
