Easy Method to OST to MBOX
camilia
You can try OST to MBOX conversion tool to recover corrupt OST emails and also save OST data in MBOX formats without creating any issue. It is the very simply works to convert OST to MBOX, Outlook, PST, office 365, Zimbra, Live Exchange, vCard/vCal, MSG, EML, and HTML etc.) along with mailbox, inbox, outbox, sent items, deleted items, email, properties, journals, junk mail, subject, attachments, calendar).
* Recover inaccessible emails & mails files of OST
* Import OST to MBOX format easily
* Convert OST to MBOX, PST, Zimbra, Office 365, live Exchange, EML, MSG, HTML, EML/EMLX, vCard/vCal, etc.
* 100% available & show to split option.
* Filter messages by date/folders/size etc.
* Software supports all MS Outlook versions-: 2019/2016/2013/2010 and 2007. More Info-: http://www.osttopst-converter.com/blog/import-ost-files-to-pst.html
The best technique to convert OST to MBOX is by using DRS OST to PST Converter Tool. It is an advance option to migrate OST data into any other file format and email client. The utility is very easy to use and also provides security to your data. If you want to migrate your files by using this application then you can download its free demo version and complete your task within a very short time. However, I have recently used another software named as MigrateEmails OST to PST Converter Tool. It is very easy to use and offers security to the data while performing the conversion task.
As a user, I suggest using a professional OST to MBOX Converter Tool to efficiently convert OST files to MBOX to access your Outlook files in Thunderbird in Windows and Apple Mail in Mac. This is a risk-free tool that can bulk/single convert and migrate OST files into MBOX file format.
I have used Magus ost to pst converter tool, You can also try this.
Download SysInspire OST Converter Software to convert OST to MBOX without any loss of OST file data. Users do not need any technology-based knowledge to run the software because it comes with a user-friendly graphical user interface that helps technical and non-technical users for operating the software effortlessly. It securely imports OST files to MBOX and other various formats. Use the free demo version of this tool where you can import 25 items from each folder of the OST mailbox to MBOX free of cost.
Read More: Easy Method to OST to MBOX
You can use CloudMigration OST to PST Converter Tool to convert OST file to PST, MBOX, EML, EMLX, PDF, etc. It Migrates OST to Gmail, Yahoo, AOL, etc. This tool has many advance features. You can converts file in bulk. Non-technical users also use this tool very easily. Try its free demo version.
Ignissta OST Converter is best OST to PST Converter utility software which provide Safe and secure OST to PST Conversion Results. While using OST Converter by Ignissta you can convert OST to PST File with Ease.
Download OST Converter from this link https://www.ignissta.com/ost-to-pst-converter/
Important Features for Ignissta OST Converter
  1. No File Size Limitations, Convert Unlimited OST Files to PST Files
  2. Provide Safe and Secure conversion results with 100% Data security
  3. Supported all MS Outlook Versions like: 2019, 2016, 2013, 2010 and 2007, 2003
  4. Capable to convert multiple file format like: PST, Office 365, EML, MSG, Vcard and MBOX
Browse OST file ---------->
Preview Mail Items ----------> Export to PST File
