Easy Module to Convert Offline OST file to PST
Use the risk-free method to convert OST data to PST. There are two methods to convert offline OST file to PST file. Explain the free method to convert OST to PST File.
  • Open MS Outlook Utility and Select file option to import & Export Method.
  • In the Export & Import method to create an Outlook Backup PST file.
  • Easily Open the Outlook PST file in Outlook.
The second Module Using third Party, Just use third-party solutions like OST to PST converter tool to make the conversion easy. Before the conversion process, it shows a preview of the recovered mailbox. It easily tackles all kinds of problems and converts the data easily into a new accessible file format which is PST. Using this tool the user can convert single as well as multiple files at a time without any hassle. You can split a large file into as many mini files as you need. It has multiple file formats to store the final result which are PST, EML, EMLX, MBOX, HTML, vCal, vCard and MSG.
Read More: Freeware OST to PST Converter Software to Convert OST File To PST
Convert single as well as multiple OST files at a time with the help of SysVita OST to PST converter tool which has the best features to make your conversion smooth and reliable. Before conversion, it shows a preview of the recovered mailboxes including Email, Tasks, Attachments, Drafts, Notes, Inbox, Contacts, Calendar (To, Cc, Sender, Date, Time, Subject, Object and Bcc). Using this tool you can convert your OST file data to PST, EML, EMLX, MBOX, vCal, vCard, HTML and MSG. SysVita OST Converter Software easily Migrate OST to Office 365 & Live Exchange Server, G-Suite, Gmail, Yahoo, & AOL. This tool easily splits a large file into multiple mini files as per your requirement. It supports MS Outlook versions 97, 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019.
Read More: OST to PST Converter Software
Download OST to PST Converter you can convert single as well as multiple files in a few little moments included with email, notes, attachment, contact, sent item, delete item, journals ( To, CC, Bcc, From, Subject, Object, Date and Time). If you face any problem to operate this tool so you can contact our experts 24x7 hours, they are always ready to help you in every critical situation. Try the free demo version of this tool to convert 30 emails for free.
