ATS OST to PST Converter will automatically do the scanning of OST files before the recovery and conversion.
- ATS OST to PST Converter will automatically split the PST file into multiple files based on the size limitation of the Outlook PST.
- ATS OST to PST converter can easily recover mailboxes, which have been deleted knowingly or unknowingly.
- Recover and Save OST files as EML, MSG, MBOX, vCal, vCard etic format.
- In addition to saving the recovered data as PST file, it also allows you to save the recovered data as MSG, EML formats.
Read More: https://ats-ost-to-pst-converter-toolkit.en.softonic.com/
You can also use this expert WholeClear OST to PST Converter, which helps you to convert multiple exchange OST files to PST format with all emails, formatting, and attachments without any data loss. This tool can easily convert your exchange OST mailbox into PST formats such as attachments, messages, calendars, contacts, drafts, tasks, notes, journals, distribution lists, appointments, sent items, and much more. It has a very simple GUI, anyone can easily handle and works with the software without a technical expert's help. It keeps all the folder structure data items during the conversion process.
