Easy way to Access unreadable Outlook OST file by using ATS OST Recovery tool
By taking the help of this tool you can convert emails, draft, task, attachment, inbox, notes, calendar and many more by taking the help of ATS OST Recovery Tool application you can migrate single as well as multiple files at a one time without facing any difficulty. This tool has a preview facility that shows the preview of recovered mailbox along with the metadata properties like To, Cc, From, Date, Time, Subject, Object, and Bcc. It backing OS Windows’s version 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit). The user saves the final result into PST, EML, EMLX, MBOX, vCal, vCard, HTML.
Read More details: Exchange OST Recovery
Don't use any other apart from OST to PST Converter tool because it is one of the best tool for converting the data from Outlook OST file to PST file format. If your OST file heavy in size so you can split it into several little PST file formats. Before finishing the conversion it displays recovered mailbox along with all the data such as email, draft, task, attachment, notes, contact etc. After the conversion, you save your data into several file formats such as PST, EML, MBOX, HTML, vCal, vCard, EMLX, and MSG. Apart from its support cloud-based application Office365 & Live Exchange Server.
Read More Info: OST to PST
You can try to easily method to converting ost file into pst file format. this software highly advances technological algorithms convert ost file in pst file and save another file format as PST, MSG, EML, MBOX, EMLX, vCal, vCard, and HTML.
Read More: Sysmaipro OST to PST Converter
Vartika for OST Recovery Tool is easy way to access unreadable Outlook OST file including all its elements as such- inbox items, sent items, contact, calendar, journals, deleted folder items and many more formats. OST Recovery Tool authenticate to access OST file items into PST, EML, MBOX, HTML and other formats. It gives you various features at lowest price.
If you are looking for the easy and secure way to access the data from the unreadable OST file, use eSoftTools OST Recovery Tool for the smart recovery of the corrupted OST file and folder. This program easily converts all OST file folder including E-mails, Chats, Contacts, Appointments, Inbox-Outbox items, Drafts, Sent Items, Calendar, Tasks, Notes, Journal folders. For the conversion option, it offers multiple formats to the user like Office 365, MBOX, CSV, EML, MSG, vCard, HTML, PST Outlook. A smart preview is available to the user before the conversion of OST file.
Get more info:- https://www.esofttools.com/ost-recovery/
Simple and Easy OST to PST Conversion Process with IGnissta OST to PST Converter Software. Must Download and Install Trail Edition which is freely available.
Why Use Ignissta OST to PST Converter
# No File Size Limitation, Export and Convert Large OST file to PST
# 100% Safe and Secure conversion results without any data loss
# 100% Fast Process as compare to other solutions
# 24*7 Customer Support for any assistance
# Support all Outlook versions 2019, 2016, 2013, 2010 and 2007
# Multiple file Format supported like EML, MSG, Office 365, Vcard, MBOX and PST
Download Trail Version Now https://www.ignissta.com/ost-to-pst-converter/
1. Browse OST file
2. Preview Mails Items
3. Export to PST
The appropriate tool for the conversion of OST file into PST file is eSoftTools OST to PST Converter Software. This perfect software has the features which is liked by every user. Some of the characteristics are gives a smart preview of OST files, recover corrupted OST files and also helps to convert OST file in other formats like Office 365, HTML, MSG, EMLX, EML, MBOX, etc. For more knowledge about the software just try the FREE TRIAL VERSION given by the Software developer in which you can save upto 50 files from each folder.
Get More:- OST Recovery
