EDB to Outlook Conversion software
If you are searching an EDB to Outlook Conversion software then I’ll recommend you try eSoftTools EDB to PST converter software which lets the user recover and convert EDB’ into Outlook without modifying any single bit of data. All the elements of the mailbox consisting of messages, calendar, contacts, notes, journals, tasks etc can restore easily. It allows the user to split a PST file into many new PST file easily. The free version is available on their official website to try. Apart from PST file, it can even change the file format into other formats like EML, MSG, EMLX, HTML, MBOX, etc.
Get More Info:- EDB Recovery Tool
