ethanbrowns
Take at the assistance of InQuit EDB to PST Converter application that is the third-party tool. It gives an accurate result that is better than your expectations. Before finishing the conversion process it will show you the preview of the recovered mailbox along with email, notes, contact, attachment, task, and many more.
During the conversion process, it never makes any changes in the database without any hassle. The tool is equipped with all the latest facilities and all the need of users. If you want to migrate the data of EDB file into another format apart from PST, then it is possible. Because of this tool support Outlook PST, EML, EMLX, MSG, vCal, vCard and MBOX file. You can also migrate the data into Office365 & live Exchange server.
It is compatible to work with all the versions of MS Outlook 2019, 2016, and all the below version. For the conversion task, there is no need to install MS Outlook on your system because it easily works on the absence of the MS Outlook. The working ability of this tool is amazing that makes it quite unique from other tools. Through the help of this application, you can take the advances and migrate your pub1edb and priv 1edb file without any trouble. It is very simple to use.
Then don’t take tension that is possible because the application provides a free demo version to migrate 30 emails from each and every folder without money. If you have many files, you need to purchase the full version of this tool.
Quick Steps to Convert EDB to PST
Step 1: Download https://www.inquitsoftware.com Install the InQuit EDB to PST Software.
Step 2: Select Corrupt EDB file to convert them into PST File.
Step 3: Preview EDB mailboxes Items and select the mailboxes to export to PST.
Step 4: Export selected mailboxes or folders to PST.
Step 5: Get the desired result.
Supports different formats: EML, MSG, HTML, office 365 & Live Exchange
