ethanbrowns
To convert EDB to PST Converter user need a software which is simple, easy to use, smooth and also reliable. It is mainly designed for the conversion process. Before the actual conversion you can also be able to see the preview of recovered mailbox, then convert the data into multiple file formats like PST, EML, EMLX, vCal, vCard, MBOX, etc. it supports OS window s version 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1, 10(32 bit& 64bit). It also supports the cloud-based application Office365&Live exchange server. The help of this converter you can convert your lost and permanently delete data in a couple of clicks. It also provides an auto scanning facility to scan the OST file. You can also take a free demo in which you can easily convert 30 emails per folder, but if you want to convert more files, then you need to buy this program from its official website. It provides 24*7 technical support to the user. After making a purchase, if you are not satisfied with it, you can easily return it within 30 days of purchase.
Read More: https://www.inquitsoftware.com/en/pages/edb-to-pst-converter.html
