EDB to PST Converter Tool
An excellent Exchange recovery software We are using an Exchange server in our organization and encountered problems with it. We looked for a free tool online that could immediately recover the mailboxes without much effort. After looking around, we came across the EDB to PST tool. We first used the trial version and found and quite satisfactory for our requirements. Since we had a large number of mailboxes to recover, we purchased a license easily and quickly recovered all our mailboxes and we could directly migrate the contents to another Exchange server. The tool just saved our precious time and efforts and we are now relieved that all our data is safe. It's a very simple tool that easily works in all Windows operating systems and MS Outlook versions like 2019, 2013, 2010, 2007, 2003, 2016, and 2000. It gives you the opportunity to convert EDB files to PST and various file formats such as EML, MSG, HTML, vCard, etc. Users can select any of these file formats to export Exchange EDB emails.The program allows to export mailboxes from EDB to Live Exchange Server.You can conveniently convert EDB mailbox items such as emails, contacts, calendars, events, notes, etc. to PST file format.The tool just saved our precious time and efforts and we are now relieved that all our data is safe.
Read more :- EDB to PST Converter Tool
Many experts usually endorse using specialist third-party software to convert EDB to PST. And Shoviv Software develops an advanced multi-functional EDB to PST converter with powerful algorithms. This program combines a simple graphical user interface (GUI) with many user-friendly features and options, such as:
  • It allows you to convert several EDB files to PST at once.
  • This software recovers data from damaged EDB files and fixes them before storing them in a PST file.
  • This tool allows you to preview added file items before initiating the conversion.
Users can check this tool's functionalities to convert EDB to PST through the free demo version.
Read More: www.shoviv.com/convert-edb-to-pst.html
Exchange EDB to PST Converter offers an excellent way to recover corrupt EDB files. This utility can easily fix the corruption if the file becomes damaged or corrupt. Depending on the degree of corruption, users can choose from a number of recovery modes. With the help of this utility users can open edb file without an exchange server.
SysOZ EDB to PST Converter utility shows the preview before the conversion process than convert into different-different file formats like PST, MSG, EML and HTML according to your need. This application supports OS Windows up to Win 10 (32bit& 64 bit). The user can easily export selective data into PST and another format with the help of this tool.
Read More: SysOZ EDB to PST Converter
