Effective Way To Recover Corrupted OST Data
Use the best technology to make your OST files accessible again that is OST to PST Converter which is equipped with very useful features like it can divide the heavy and large files into small files so that it can save your precious time, it also migrates whole data in just a few of clicks without any difficulty. The application is accurate and convenient. Provide free demo version to convert 30 emails from each folder.
Best Features Below
• Retrieves of emails, inbox, sent the item, deletes an item, attachment, calendar, draft, task, notes( to, cc, bcc, from, object, time and date)
• Using these software users can divide their large OST file into uncountable PST files without facing any difficulty.
• It gives 24 x 7 technical support to communicate with our experts.
• It supports cloud-based application Office365 & live Exchange server which is a surplus feature of this software.
• Capable to supports all versions of MS Outlook 97, 98, 2000, 2002, 2003, up to 2019 etc.
• Compatible to supports multiple file formats PST, MSG, 65, EMLX, MBOX, HTML, vCal, vCard, and EML.
Read More Info: https://inquit-ost-to-pst-converter-toolbox.en.softonic.com/
Download PDS OST File Recovery that repair corrupted OST file and recover OST to PST File with email properties- to, bcc, cc, time, subjects and from, email header information, embedded images etc. OST file Recover Software perfectly extracts all OST emails, contacts, calendars, task, notes, and inbox items, outbox items and appointments. It gives the option to Split large size of PST file into Small PST File up to 5GB.
Read more- Free to Convert OST to PST by using OST to PST Converter
With the help of Vartika OST to PST Recovery Software you are eligible to recover each and every elements or subfolders from damaged/corrupted OST file. You can also recover deleted folder items and save into different forms as EML, Office 365, Live Exchange Server, MSG, HTML, PDF and MBOX without change in data integrity. It filters emails between two selective dates using “Message filtering option”.
Get Software-
OST to PST Recovery
