EML to PST Applicationconverts EML to PST & PST to EML
dechristan
ViceVersa EML to PST Converter software converts EML and PST files and also convert PST to EML and permits you to convert multiple EML files to PST. This software has a user-friendly and unique interface that allows both non-technical and technical users to export files without difficulty. This software allows you to convert an entire EML file folder or a subset of emails into an Outlook PST file while keeping the structure intact. It exports attachments while preserving the formatting of the original email. You may simply organize emails using the EML to PST Converter by properties such as To, From, Sent, Subject, Date, Size, and Received Date.In this software users will be able to convert an infinite number of PST files to EML at once with the help of PST to EML Converter. Additionally, several incredible opportunities will make the process easier and produce the required result in a matter of seconds with 100% accuracy.
I recently used Softaken EML to PST Converter and frankly it is a very easy and fast tool. I had a lot of old EML files that needed to be used in Outlook.
This tool converted all the emails to PST without any data loss. The best part is that Outlook was not required and the folder structure remained intact.
If anyone wants to transfer EML files to Outlook in a safe way, then definitely try this tool.
